Re: VBA to check LeaderLineStyle in a Note
Manikandan Babu Apr 13, 2017 8:29 AM (in response to Cad Admin)Hi Cad Admin,
Dim swmodel As SldWorks.ModelDoc2
Dim swnote As SldWorks.Note
Dim swann As SldWorks.Annotation
Dim swselmgr As SldWorks.SelectionMgr
Set swmodel = swApp.ActiveDoc
Set swselmgr = swmodel.SelectionManager
Set swnote = swselmgr.GetSelectedObject6(1, -1)
Set swann = swnote.GetAnnotation
Debug.Print swann.Leaderlinestyle '6
swLineCENTER 4 swLineCHAIN 3 swLineCHAINTHICK 6 swLineCONTINUOUS 0 swLineDEFAULT 7 swLineHIDDEN 1 swLinePHANTOM 2 swLineSTITCH 5 Manikandan
Cad Admin Apr 13, 2017 8:40 AM (in response to Manikandan Babu)How would i check leader vs no leader?
Manikandan Babu Apr 13, 2017 8:44 AM (in response to Cad Admin)Dim swApp As SldWorks.SldWorks
Debug.Print swann.GetLeaderStyle swNO_LEADER 0 = No leader
Cad Admin Apr 13, 2017 9:26 AM (in response to Manikandan Babu)Manikandan,
Basically i'm looking to add a leader/no leader check to this ....only want it to process notes with leaders
Option Explicit
Const NumStrings As Long = 3
Dim initString(NumStrings) As String
Dim newString(NumStrings) As String
Private Sub InitStrings()
' Initial strings from drawing
initString(0) = "2012-sm"
initString(1) = "WEIGHT:"
initString(2) = "FINISH:"
' Strings to replace initial strings in drawing
newString(0) = "NEW 2012-sm"
newString(1) = "NEW WEIGHT:"
newString(2) = "NEW FINISH:"
Private Sub DoReplaceString(ByRef sNoteText As String)
Dim i As Long
For i = 0 To NumStrings
sNoteText = Replace(sNoteText, initString(i), newString(i), 1, -1, vbTextCompare)
Next i
Dim swModel As SldWorks.ModelDoc
Dim swView As SldWorks.View
Dim swNote As SldWorks.Note
Dim sNoteText As String
Dim nTextCount As Long
Dim i As Long
InitStrings
Set swModel = swApp.ActiveDoc
Set swDraw = swModel
Set swView = swDraw.GetFirstView ' This is the drawing template
While Not swView Is Nothing
Set swNote = swView.GetFirstNote
While Not swNote Is Nothing
If swNote.IsCompoundNote Then
nTextCount = swNote.GetTextCount
For i = 1 To nTextCount
sNoteText = swNote.GetTextAtIndex(i)
DoReplaceString sNoteText
swNote.SetTextAtIndex i, sNoteText
Next i
Else
swNote.SetText sNoteText
Set swNote = swNote.GetNext
Wend
Set swView = swView.GetNextView
Wend
Cad Admin Apr 13, 2017 1:56 PM (in response to Cad Admin)Added the Getleaderstyle check in & works great...
Dim swAnn As SldWorks.Annotation
Dim LeadStyle As String
Debug.Print "Text = " & sNoteText
Next i
Else
Set swAnn = swNote.GetAnnotation
LeadStyle = swAnn.GetLeaderStyle
If LeadStyle > 0 Then
Else
Wend
