GetTableAnnotations Method (IBomFeature) returns empty array
Question asked by Xavier Rodríguez Nieto on Apr 12, 2017
Latest reply on Apr 13, 2017 by Peter Brinkhuis
Dear all,
I have a problem with the 'GetTableAnnotations' method of the 'IBomFeature' object, I'm quite sure that it's returning an empty array, event when the BOM table in the drawing is not empty.
The process of getting the 'IBomFeature' works OK, I have checked it with the 'Name', 'TableType' and other properties and the results are as expected, so I assume that the pointer to the BOM works properly.
The code it's like this:
______________________
Option Explicit
Dim swApp As ISldWorks
Dim swModel As IModelDoc2
Dim swFeat As IFeature
Dim swBom As IBomFeature
Dim vTableArr As Variant
    Set swModel = swApp.ActiveDoc
    Set swFeat = swModel.FirstFeature
    Do While Not swFeat Is Nothing
        If swFeat.GetTypeName2 = "BomFeat" Then
            Set swBom = swFeat.GetSpecificFeature2
            vTableArr = swBom.GetTableAnnotations
            MsgBox (swBom.Name & " - " & swBom.GetTableAnnotationCount & " - " & UBound(vTableArr))
        Set swFeat = swFeat.GetNextFeature
    Loop
_________________________
In my drawing I have only one BOM inserted named "Lista de materiales1", and what I get prompted is:
I've tried with different drawings, different types of BOM (top level only, parts only, indented no numbering, indented flat numbering...), I don't know what's wrong.
Any idea?
