When I insert fastners out of the toolbox and then save and
close. When I reopen the assy the fastners have all changed sizes
from what I originaly inserted.
You can open the each different type of fastener and "save
as" and give it a slightly different file name, or alternatively if
you use pdm works workgroup or enterprise it all gets taken care of
for you when you check the assembly in
We are having the same problem. It would seem that each
fastener would have it's own unique name based on it's size and
configuration. Do you mean to say that for each size of socket head
cap screw we must name it as such?
Are you working on the network or local drive.
