Hello Forum,
I am following the example to mate a part with an assembly. 2017 SOLIDWORKS API Help - Add and Mate Component Example (VB.NET)
My question is about the flowing two lines...
boolstat = swDocExt.SelectByID2(FirstSelection, "PLANE", 0, 0, 0, True, 1, Nothing, swSelectOption_e.swSelectOptionDefault)
boolstat = swDocExt.SelectByID2(SecondSelection, "PLANE", 0, 0, 0, True, 1, Nothing, swSelectOption_e.swSelectOptionDefault)
The FirstSelection and SecondSelection are defined as Strings. boolstat is Boolean.
Because I have a selection command in UserPMPage.vb. so I want to use the selected object directly. Thus I rewrite the codes as follows...
Dim FirstSelectedObject as Object
FirstSelectedObject = swSelectionManager.GetSelectedObject6(1, -1) 'Get the selection from the user PMPage selection controll
...And then run the AddMate5.
I could tell you that my code does not work, sadly. The difference between my code and example is mainly on the GetSelectedObject6. I have tried a lot of ways, but just could not get the correct method... Although I dont think the selection method is wrong, because sometimes we need to do so on SolidWorks.
Could somebody please give me some hints? Thank you in advance!
Codes looks fine. Once you run the macro, do a force rebuild and that should show the mate. If this works then, add a force rebuild line in the end of code after the addmate line
