Hi all, I need help.
So here are some pictures of what I'm building: http://imgur.com/a/Ef4so
So basically what I want to do is create some diagonal burrs along the interior of the grinder. I can provide a picture of the real world object if needed. However, I'm not sure how to do that. Solidworks won't let me sketch on a cylindrical surface, and if I cut extrude from a sketch from the top view, I'll get burrs but they'll be vertical, not diagonal. I'm at a loss at what to do...
Any help is greatly appreciated!
Hi Mario,
Post up the image of the real life object so we can see where you want to be going. From your description though, if diagonal cuts on the face of a cylinder are the same as helical cuts going down the face of the cylinder then you might want to take a look at the attached model and see if this is what you are looking for.
