API to link weldment cut list placed on each sheet to all the views of this sheet
Question asked by Sebastien Kitten on Apr 8, 2017
Latest reply on Apr 8, 2017 by Deepak Gupta
I currently use a macro that scans all the views for each sheet placed in a drawing and assigns the BOM table placed on each sheet to all the views present on this sheet. This works pretty well, excepted when it comes to weldment cut list. I would like to adapt this macro so it works exactly the same way when the sheet has a weldment cut list instead of a BOM. I don't want to replace the weldment cut list with a BOM including the detailed cut list. I don't succeed in getting the feature name of the table when it is a weldment cut list. Here is my code, I'm looking for some help to correct the "If TableType = 4 Then" test.
Dim swTableAnnotation As SldWorks.TableAnnotation
Dim swBOMAnnotation As SldWorks.BomTableAnnotation
Dim swBOMFeature As SldWorks.BomFeature
Dim swWCLAnnotation As Variant
Dim swWCLFeature As SldWorks.WeldmentCutListFeature
Dim View As SldWorks.View
Dim vSheetName  As Variant
Dim i As Integer
Dim TableType As Long
Dim BOMTableName As String
Dim WCLTableName As String
Set swModel = swApp.ActiveDoc
Set swDraw = swModel
Set Sheet = swDraw.GetCurrentSheet
vSheetName = swDraw.GetSheetNames
    For i = 0 To UBound(vSheetName)
        swDraw.ActivateSheet vSheetName(i)
        'FindBOM
        'Get the first View from the DrawingDoc
        Set View = swDraw.GetFirstView
        'Traverse all the TableAnnotations for the View looking for BOM table type_
        Set swTableAnnotation = View.GetFirstTableAnnotation
        Do While Not swTableAnnotation Is Nothing
            TableType = swTableAnnotation.Type
            If TableType = 2 Then ' BOM
                Set swBOMAnnotation = swTableAnnotation
                Set swBOMFeature = swBOMAnnotation.BomFeature
                BOMTableName = swBOMFeature.Name
                Debug.Print "BOM on this active sheet: " & BOMTableName
            If TableType = 4 Then ' WeldmentCutList
'                Set swWCLFeature =
'                BOMTableName = swWCLFeature.Name
'                Debug.Print "Weldment Cut List on this active sheet: " & BOMTableName
            Set swView = swDraw.GetFirstView
            Set swView = swView.GetNextView
                While Not swView Is Nothing
                    swView.SetKeepLinkedToBOM True, BOMTableName
                Wend
        Exit Do
        Set swTableAnnotation = swTableAnnotation.GetNext
        Loop
    Next i
Thanks.
Sebastien
