6 Replies Latest reply on Apr 9, 2017 7:11 AM by Peter Brinkhuis
    VBA to Change Balloon Leader Type
    Cad Admin
      I currently run a macro that selects all the balloons on a drawing sheet & formats them using
      Set myNote = swModel.Extension.EditBalloonProperties2(swBalloonStyle_e.swBS_Circular, swBalloonFit_e.swBF_3Chars, swBalloonTextContent_e.swBalloonTextItemNumber, "", 0, "", 0.01016, False, 1, "X", 0.0035)
      However this doesn't control the "leader style"...  i found SetLeader3, does it apply to "balloons" or just note/annotations?  If so i would want to set all leaders to swStraight.
        • Re: VBA to Change Balloon Leader Type
          Keith Rice
          Balloons are considered a note (and therefore a type of annotation) in SolidWorks.
          Keith
          SolidWorks API Training and Services
            Cad Admin
            So in my code, i need every balloon leader changed i can alter under Set myNote, similarly too the edit balloon code?  Sorry i see Daft today
                Raghvendra Bhargava
                Try this:
                Dim ann As Annotation
                Dim swNote As Note
                Set swNote = Part.SelectionManager.GetSelectedObject6(1, -1)
                Set ann = swNote.GetAnnotation
                Dim longError As Long
                longError = ann.SetLeader3(swLeaderStyle_e.swSTRAIGHT, 0, False, False, False, False)
                    Cad Admin
                    I'm Getting a type mismatch...on Set swNote = swModel.SelectionManager.GetSelectedObject6(1, -1)
                    Code is below
                    Option Explicit
                    Dim swApp           As SldWorks.SldWorks
                    Dim swModel         As SldWorks.ModelDoc2
                    Dim Part            As ModelDoc2
                    Dim swDraw          As SldWorks.DrawingDoc
                    Dim vSheetName      As Variant
                    Dim i               As Integer
                    Dim bRet            As Boolean
                    Dim boolStatus      As Boolean
                    Dim longstatus      As Long, longwarnings As Long
                    Dim myNote          As Object
                    Dim swNote          As Note
                    Set swModel = swApp.ActiveDoc
                    Set swDraw = swModel
                    ' Get the sheets in the drawing document
                    vSheetName = swDraw.GetSheetNames
                    ' Traverse the drawing sheets
                    For i = 0 To UBound(vSheetName)
                       bRet = swDraw.ActivateSheet(vSheetName(i))
                    ' Fix balloon format
                    boolStatus = swModel.Extension.SelectByID2("Sheet1", "SHEET", 0.447009512681891, 0.454793066248622, 0, False, 0, Nothing, 0)
                    boolStatus = swModel.Extension.SketchBoxSelect("0.0", "0.0", "0.000000", "100000", "100000", "0.000000")
                    ' Fix balloon leader format
                    swModel.ClearSelection
                    Next i
                        Peter Brinkhuis
                        The issue here is that you select everything first and then assume that every selected item is a note. In my case it worked when I used the second selected item, which means the first item is something else.
                        I think you should try either:
                        1. To find a better way of selecting all balloons
                        2. To check the type of the selected item(s)
                            Peter Brinkhuis
                            I tried to find all balloons and change their leader style. I selected all notes programmatically instead of trying to imitate the user's actions. Because I had trouble identifying balloons from revision symbols, I added the check with the balloon size. You might need other checks to make sure you only change balloon styles.
                            Option Explicit
                                Dim swModel         As ModelDoc2
                                Dim swDraw          As DrawingDoc
                                Dim swView          As View
                                Dim swNote          As Note
                                Dim swAnn           As Annotation
                                Set swView = swDraw.GetFirstView
                                Set swView = swView.GetNextView
                                While Not swView Is Nothing
                                    Debug.Print "---------"
                                    Debug.Print swView.Name
                                    Set swNote = swView.GetFirstNote
                                    While Not swNote Is Nothing
                                        Debug.Print "Note name: " & swNote.GetName
                                        Debug.Print "Balloon size: " & swNote.GetBalloonSize
                                        If swNote.GetBalloonSize > 0 Then
                                            Set swAnn = swNote.GetAnnotation
                                            Debug.Print "Setting balloon leader"
                                            'swann.SetLeader3 add settings here
                                        Set swNote = swNote.GetNext
                                    Wend
                                Wend
