I'm having problems making my .Net addin create Intersection Curve between a plane and a solid body.I have already get the Intersection Curve, Furthermore,I want to get the curve parameters of Sketch3DIntersections.my kernel code is below:
RefPlane myRefPlane = null;
myRefPlane = ((RefPlane)(swDoc.FeatureManager.InsertRefPlane(8, 0.005, 0, 0, 0, 0)));
swDoc.ClearSelection2(true);
swDoc.Sketch3DIntersections();
boolstatus = swDoc.Extension.SelectByID2("", "FACE", 0.015, 0, 0.01, true, 0, null, 0);
boolstatus = swDoc.Extension.SelectByID2(''datum plane'', "PLANE", 0, 0, 0.05, true, 0, null, 0);
swDoc.SketchManager.InsertSketch(true);//I can get a 3d sketch successfully here
SketchSegment skSegment2 = null;
SelectionMgr swSelectMgr = null;
swSelectMgr = (SelectionMgr)swDoc.SelectionManager;
skSegment2 = (SketchSegment)swSelectMgr.GetSelectedObject6(1, -1); //step1
swCurve = (Curve)skSegment2.IGetCurve();
SplineParamData swSplineParaData = default(SplineParamData);
swSplineParaData = (SplineParamData)swCurve.GetBCurveParams5(false, false, true, true);
when I go to the step1,It warns me that I can't transform com object“System.__ComObject” to interface “SolidWorks.Interop.sldworks.SketchSegment”,I have seen similiar use in the API help.so what should I do to get the parameter of the curve?
Best Regards,thanks
Moon
Can somebody help me with the problem?I have tried some methods on the website https://forum.solidworks.com/message/363541#comment-363541 ,but the warning still exits !
