We are working with assemblies in wich all the parts included
have DT (external ones). The assembly and the subassemblies have
also DT.
The problem is that many times opening the assembly, not all the tables are edited and updated, most of the times, the last assembly to be opened (the main assembly) is not updated. I don't know why, because if I close this assembly leaving opened the parts, and I open again the assembly, it's updated. The thing is that is not possible to be sure if is going to be updated or not, because is making the error ramdomly.
Other times we have a message from SW like: " There's no enough memory to complete the operation", "It's not possible to the carry out the server aplication" (sorry, but I'm traslating directly from Spanish, so maybe it is not exact).
Other times, SW is resumed directly.
A complete nightmare!!
Does anyone have this problem, or somethig similar?
We are thinking that maybe is something we are doing wrong, but maybe can be the Office version, 2007?, or something wrong with SW?
Someone can help?
Someone can help?
When dealing with design tables on multiple layers, it's often necessary to rebuild a couple of times depending on how deep the changes are or need to go.
As for your error message, it sounds like you're maxing out your RAM. What are your system specifications (CPU, RAM, OS, etc).
