A co-worker found how to phantom the part while held in a fixture on a drawing.<br />This is the work around: On the drawings convert entities of the part edges, change to construction lines and hide the part in the assembly model<br /><br /><edit> (should appear under drawings heading)<br /><br />
In the drawing view, right click on the part. One of the options will be "Component Line Font..." Select that.
un-check "use document defaults", and for "Visible Edges" select a line style of Phantom (or whatever you choose). After clicking OK the component should have edges that are phantom.
