Good day to all,
I have an assembly and I cut extruded some holes through a circular pipe. Why cannot my sketh relation keep their references when I change something.
You can see this bellow.
Thank you!
Good day to all,
Thank you!
Eugen,
Your cut is supressed, I'm not sure if it will update when supressed. You could also try a Ctrl Q rebuild to see if it will update correctly.
Kevin,
As you see I highlighted the sketch and the relations. In order to do that I have to enter in the edit mode of the cut feature, so thats why is supressed. That is the reason I asked, because I rebuilt many times and still not a change. The only solution I find is to delete the relation concentric and make it again.
check the diameter of the part it is linked to??
looks as if this diameter is too small for the hole you need.
'change something' is quite ambiguous and won't help problem solving. What are you changing?
What have you made the sketch concentric to? an edge?
Try turning on temporary axis and mating the circle to the correct axis.
