I am trying to create a Default output path with a variable included. Has anyone been able to achieve this or have an example? I would like to have it read:
Vault Root Folder Path\PDF Released\123456700\<VariableValue> The 123456700 would change from file to file with the name of the PDF.
Hi Jason,
It is possible. I've done this many times. Go to the knowledgebase and search for solution ID# S-054527
It has good instructions for modifying the Advanced Scripting Options VBA code to get the job done.
Word of caution: When writing your code, make sure you understand when you are getting SOLIDWORKS custom property variable values and PDM data card variables. Especially if the PDM variable is mapped to a different name for the SW custom property (i.e. PDM var "Part Number" = SW custom prop "PartNO")
Hope this helps,
Tim CEPA
Believe in The Q!
