Good evening, for my master final graduation project in a desalination station, I wish to make a water simulation on a long piping, which exceeds a hundred meters with elbows of 90 °, the entrance comprises 4 pumps Which give in the 12 bars, which come together in a collector and that goes up to the RO part, I wanted to know a little the behavior of the water in the piping and if there is a loss of pressure through the singularities , Is it possible to treat a long pipework in solidworks? thank you
As i understand , you can define an inlet flow for pumps location and you will see water behaviour along the lon pipeways.
Maybe this video gives you a hint
pipe in flow simulation - YouTube
However you are working on a mixing study, so you have to create more mesh.Maybe 10 cell for section.
This causes more calculation time
