Hello all,
I am working on line diagram on Solidwork Electrical.
I have completed symbol insertion. Now I am drawing cables and facing two problems as below-
1) I am getting this mark near cursor while drawing the cable. What does this mean? ( Refer image "cable")
2) For some cables, I am getting correct junction point ( pink dot) at the junction. But for some cables at junction points I am not getting the pink dot. Eg- In the image , above component Q21 junction point is not getting created. What should be the reason? ( Please refer image "cable 2")
Thanks in advance!
Regards,
Namita Zaware
Yes, simply because it was not designed to show connections that way. The cables will only attach to symbols, not other cable lines. So that junction dot is really an unconnected cable, laying on top of another cable line so that it doesn't look like it. Are you trying to draw a harness? Like it is one connector at one end with two connectors at the other? That would look like my screenshot below.
