The sketch16 is producing error message. What is the reason?
Just an over defined sketch, when you run into over definition go to Display/Delete Relations to see all relation in sketch...
Delete Coincident 15 and the sketch will be happy again...
Problem is same no improvement. I want to revolve this sketch.
you have an issue with this line...
a quick method to verify closed contours is to try and extrude the sketch/profile, when I did that I got this error message that helped me understand where to look closer at the end points...
Best, J
