Hi
I would like to know if there is a way of creating a data card variable that holds a user name, and then allowing a workflow transition only is the logged user matches that variable.
I could not find a way in the transition conditions to compare to anything but a fixed value.
Also if I use user permissions in the workflow, those permissions are fixed and I must create a different workflow for each possible approval sequence, which is impractical.
I think you can do that in Dispatch, but definitely not in the transition conditions. Dispatch is better for this anyway because you can create a message to the user that tells the user why the transition cannot be completed.
