When checking out a SLDDRW from the vault you can not take
ownership on the "Get Local Copy and Open Document" window. Doing
so will give you "false" ownership and when you go to check it back
into the Vault, PDMworks thinks you do NOT have ownership. The only
way for us to do it is to manualy Right CLick on the file in the
Vault and "Take Ownership", this doesn't even always work and
"Taking Ownership and Releasing Ownership" of the file must be
repeated until PDMworks realizes that you have Ownership and can
check the file in.
Anyone else having this problem?
Did this just start or has it been going on for a while, say since SP0?
Did you do a fresh install or just an update @ SP0?
Well anyway, stop the PDMW service and make a complete backup of your vault. Run the PDMW un-install from windows. This will only uninstall the program all of your files will remain. Install PDMW SP0 and point to your existing files. Download PDMW SP5 and install. This should now be a clean install and should work normally.
