Error with cut feature in VB Macro
Ahmed Eldyasty Mar 29, 2017 5:54 AMHello
i tried to make cut through a cylinder but when i run the code from API SW VSTA VB Macro it stop and gives me an error with cut feature
here is the code
Dim swDoc As ModelDoc2 = Nothing
Dim swPart As PartDoc = Nothing
Dim swDrawing As DrawingDoc = Nothing
Dim swAssembly As AssemblyDoc = Nothing
Dim boolstatus As Boolean = false
Dim longstatus As Integer = 0
Dim longwarnings As Integer = 0
'New Document
Dim swSheetWidth As Double
swSheetWidth = 0
Dim swSheetHeight As Double
swSheetHeight = 0
swDoc = CType(swApp.NewDocument("C:\ProgramData\SolidWorks\SOLIDWORKS 2017\templates\Part.prtdot", 0, swSheetWidth, swSheetHeight),ModelDoc2)
swPart = swDoc
swApp.ActivateDoc2("Part1", false, longstatus)
swDoc = CType(swApp.ActiveDoc,ModelDoc2)
Dim myModelView As ModelView = Nothing
myModelView = CType(swDoc.ActiveView,ModelView)
myModelView.FrameState = CType(swWindowState_e.swWindowMaximized,Integer)
boolstatus = swDoc.Extension.SelectByID2("Front Plane", "PLANE", 0, 0, 0, false, 0, Nothing, 0)
swDoc.SketchManager.InsertSketch(true)
swDoc.ClearSelection2(true)
Dim skSegment As SketchSegment = Nothing
skSegment = CType(swDoc.SketchManager.CreateCircle(0, 0, 0, 0.049045, 0.007529, 0),SketchSegment)
skSegment = CType(swDoc.SketchManager.CreateCircle(0, 0, 0, 0.032266, 0.007529, 0),SketchSegment)
'Named View
swDoc.ShowNamedView2("*Trimetric", 8)
swDoc.ViewZoomtofit2()
'Zoom In/Out (MouseWheel)
Dim swModelView As ModelView = Nothing
swModelView = CType(swDoc.ActiveView,ModelView)
swModelView.Scale2 = 1.1038054555528047
Dim swTranslation(2) As Double
swTranslation(0) = 0.045236861391939921
swTranslation(1) = -0.00075604615086462235
swTranslation(2) = 0.0012582720965941959
Dim swTranslationVar As Object
swTranslationVar = swTranslation
Dim swMathUtils As Object = Nothing
swMathUtils = swApp.GetMathUtility()
Dim swTranslationVector As Object = Nothing
swTranslationVector = swMathUtils.CreateVector(swTranslationVar)
swModelView.Translation3 = swTranslationVector
swModelView.Scale2 = 0.91983787962733743
swTranslation = New Double(2) {}
swTranslation(0) = 0.045365963728255923
swTranslation(1) = -0.000630038459053852
swTranslation(2) = 0.0010485600804951633
swModelView.Scale2 = 0.76653156635611441
swTranslation(0) = 0.045473549008519305
swTranslation(1) = -0.0005250320492115433
swTranslation(2) = 0.00087380006707930282
swModelView.Scale2 = 0.638776305296762
swTranslation(0) = 0.045563203408738762
swTranslation(1) = -0.00043752670767627867
swTranslation(2) = 0.00072816672256608567
swModelView.Scale2 = 0.53231358774730164
swTranslation(0) = 0.045637915408921662
swTranslation(1) = -0.00036460558973023968
swTranslation(2) = 0.00060680560213840476
swModelView.Scale2 = 0.44359465645608476
swTranslation(0) = 0.045700175409074034
swTranslation(1) = -0.00030383799144187011
swTranslation(2) = 0.00050567133511533724
swModelView.Scale2 = 0.534451393320584
swTranslation(0) = 0.079006461583123008
swTranslation(1) = 0.011208225509027191
swTranslation(2) = 0.00060924257242811735
swModelView.Scale2 = 0.64391734135010126
swTranslation(0) = 0.11913451721450734
swTranslation(1) = 0.0250781815336887
swTranslation(2) = 0.00073402719569652685
swModelView.Scale2 = 0.77580402572301366
swTranslation(0) = 0.12108418032954664
swTranslation(1) = 0.035676140599545943
swTranslation(2) = 0.00088437011529702051
Dim myFeature As Feature = Nothing
myFeature = CType(swDoc.FeatureManager.FeatureExtrusion2(true, false, false, 0, 0, 0.23000000000000007, 0.01, false, false, false, false, 0.017453292519943334, 0.017453292519943334, false, false, false, false, true, true, true, 0, 0, false),Feature)
swDoc.ISelectionManager.EnableContourSelection = false
boolstatus = swDoc.Extension.SelectByID2("Top Plane", "PLANE", 0, 0, 0, false, 0, Nothing, 0)
skSegment = CType(swDoc.SketchManager.CreateCircle(0, -0.108635, 0, 0.028008, -0.108125, 0),SketchSegment)
myFeature = CType(swDoc.FeatureManager.FeatureCut4(false, false, false, 9, 1, 0.23000000000000007, 0.23000000000000007, false, false, false, false, 0.017453292519943334, 0.017453292519943334, false, false, false, false, false, true, true, true, true, false, 0, 0, false, false),Feature)
'Named View
swDoc.ShowNamedView2("*Isometric", 7)
''' <summary>
''' The SldWorks swApp variable is pre-assigned for you.
''' </summary>
Public swApp As SldWorks
