I am attempting to create a simple interior thread but the command keeps failing.
"The sweep operation failed to complete."
My part is attached below.
Thank you for any help!
Hi Haa-Young,
If you are trying to sweep Sketch6 around the helix in this part I would expect it to fail.
The sweep operation should have the path intersect the profile.
So to make it work you should relocate the profile to be co-linear with the hole face, and intersect the profile.
You could also try the thread feature:
When I opened the part it appeared the thread was positioned on the centerline of the part. When I make threads I put the thread profile on the pitch diameter of part then I do my Sweep.
