I'm wondering if anyone can help me out with a problem I'm
having? None of my assemblies will open. The strange thing is that
my part files open with no problems. I'm using SolidWorks 2008 SP
5.0. When I try to open an assembly it begins the process of
opening but it then shuts down SolidWorks and I get a message box
stating "An error has occurred and SolidWorks needs to re-start".
The message box gives me the option to "restart and recover files".
I have selected this option several times and SolidWorks does
restart but it does the same thing when I try to open an assembly.
I have never experienced this problem before. What I can tell you
is that the problem is consistent. I have opened several parts from
several different assemblies and they all open with no problems. I
have also tried to open several different assemblies and
sub-assemblies, and non have opened and when I try they all shut
down the program and give me the same message I spoke about above.
Any help would be greatly appreciated. Thanks for your time.
Have you contacted your VAR; this is a critical issue.
Did you make any system changes prior to this occurring?
System specs?
