5 Replies Latest reply on Mar 26, 2017 5:35 PM by Amen Allah Jlili
    VB.NET AddIn - How to insert a sub to convert the unit, How to deal with small values?
    Ross John
      I am new to this forum and I am looking forward to learn from you experts.
      Also I am new to VB.NET and cannot solve these two problems on my own.
      Question 1: I have wrote some codes to convert the unit from meter into millimeter. But I dont know how to use these codes in VB.NET AddIn. Here is my code:
      Private Function convertMeterToMillimeter(Meter As Double)
          convertMeterToMillimeter = Meter / 1000
      End Function
      I want to insert the above code into the standard VB.NET AddIn codes, so that I can use this Function for all the other Subs in one project.
      For example: In the standard VB.NET AddIn file there is a line like this: (In the Sub CreateCube)
           model.SketchRectangle(0, 0, 0, 0.1, 0.1, 0.1, False)
      I want to rewrite the above line into something like this...:
           model.SketchRectangle(convertMeterToMillimeter(0),
                                                   convertMeterToMillimeter(100),
                                                   convertMeterToMillimeter(100), False)
      Could anybody please tell me, where exactly should I put the Function convertMeterToMillimeter, how to make the declarations... etc.
      Question 2: Besides, if there are small values, it seems SolidWorks cannot do correctly.
      For example: If I change 100mm into 1mm in the standard VB.NET AddIn file:
      From: model.SketchRectangle(0, 0, 0, 0.1, 0.1, 0.1, False)
      Change to: model.SketchRectangle(0, 0, 0, 0.001, 0.001, 0.001, False)
      SolidWorks will not do the job.
      How to solve this problem?
      Thanks for your help!
