Things to watch for in PV360
Question asked by Kevin Quigley on Dec 9, 2008
Latest reply on Dec 9, 2008 by 1-FOD7HK
In the current version there are a few things that I have found can be a bit of a stumbling block when it comes to setting up renders (particularly anything complex).
1. PV360 doesn't obey the saved show/hide status of assemblies - everything is on display when you open the file. (I am nearly 100% sure this was not the case in the beta phase?).
2. When you hide elements it hides things on a root level basis in the assembly. For example if your assembly has parts and sub assemblies, if you click on a part inside a sub assembly and choose hide - the entire sub assembly is hidden. The selection of entity level makes no difference here.
3. Worse than 2 though if you have duplicates of the sub assembly and you click on one to hide - they all get hidden.
