Hi all,
So I would like to edit my drafting standard such that when one dimensions a wall thickness of a tube, then it behaves in the same manner as my diameter dimension. In particular I would like the leader to have a horizontal section to display the dimension and text. See below:
I would like the dimension of 2.25mm WT above to display in the same manner as the diameter of 9.5mm does... is there a way to do this?
I can't seem to find the correct setting under document properties to change this particular type of dimension style.
Hi Gary, as this is a linear dimension I think this ability is limited- a quick test found a display option (on the right click menu) for Offset text, where you can change the position to make it look like the DIA- see below. You would have to apply this on a case by case basis though rather than having this as a document preference/template setting. I cannot find anything else that comes close I'm afraid.
Adam
