I have an assembly with 25 parts. I can't split the BOM up
because of the way our company policy (needs some work) is on items
numbers..etc.
I want to put other pages in the drawing linked to the orginal BOM listed on page 1.
Is it possible to do this??
Tim
Tim
There are a couple ways to do it. But the trick is to add the BOM on the same page as your drawing first.
Then the method we use is:
Select the upper left portion of the BOM (the cross-hair arrows)
Control + x (to cut BOM to clipboard)
Access the other sheet
Control + v (to copy BOM from clipboard)
Lastly, you have to go to the properties of the drawing you want the BOM to reference. Under the more properties button, at the bottom of the popup window (Drawing View Properties), there is a selection for Balloons. Make sure there is a check mark to link balloon text to the BOM and your particular BOM in the pulldown menu is selected. (If there is only one BOM in the dwg, then it probably is.)
Hope this helps.
Bruce
