Drawing Note Macro Help: Calling out part properties in assembly drawing
Question asked by Brett Stainken on Mar 24, 2017
Latest reply on Mar 28, 2017 by Peter Brinkhuis
I am looking for a macro to look into the properties of each part in an assembly, and if the part has a "filter" property with a "yes" in the value/txt expression, to display a note "flow" with an arrow for each part that has a "yes" in the filter property value.
This is as far as I have gotten:
Sub CreateAnote()
    Dim swApp As Object
    Dim Model As Object
    Dim str As String
    Const swDocPART = 1
    Const swDocASSEMBLY = 2
    Const swDocDRAWING = 3
Set Model = swApp.ActiveDoc
    If Model Is Nothing Then
        Exit Sub
    If (Model.GetType <> swDocDRAWING) Then
        swApp.SendMsgToUser ("Only used for drawings")
        Exit Sub
    str = "Flow>"
    Model.CreateText str, 0.09, 0.08, 0, 0.01, 0
Thanks for your help
