You can test yourself for this option
Draw a ridiculous large 2D profile and a 3D sketch for path including small bent compare to the profile and then apply swept feature
Maha.... they changed Sweep in 2016 and added a few other options.. so I believe the help description also changed or omitted some information.. btw, my screen capture was from 2015 help.
..but, yes,..."minimum twist" is doing a much better or near expected twist along path then the older default (which could be chaotic).. and/also,. I believe "minimum twist" is now the default setting for 2017.
(per your above vague statement)... I agree.. there is NO realtive explanation or definition between the default (older) sweep algorithm and the optional (newer) "minimum" algorithm. It's possible, an offical statement from SW Corp exist... some where?
