This half a body has been mirrored to make full body and Knit Surface tool applied to make combine body. But highlighting of Surface knitting in feature manager tree showing half a body only. What is the reason?
it's like split line, but all in one body - here is the image of no edges
it's like fillet
and if you don't like the line, hide it
Two questions
-Is this a only way to make sure it a one body?
-How did you remove the edge?
You can check from the FM, when you select surface-knit, all is highlight
The line is not really removed, jut hidden
