feature manager drawwing renaming macro
Question asked by Nick Gvk on Mar 22, 2017
Latest reply on Mar 28, 2017 by Nick Gvk
so i have been doing allot of work trying to convert drawwings
the problem lays withing a few things
i get drawings from china germany france and spain
they all use their own language
but the staff we work with dont speak any of these languages
so they cant work with the drawings that are provided
my job isnt converting every single file but desing new products
unfortunaly converting these drawings has become a full time job
as often the changes in my master drawwings that i send to these  company`s makes the "models items" button obsolete
because most of the time they use and imported file instead of the .sldprt
the problem :
i get sldprt files in 3 different languages
i get slddrw files in 3 different languages
the solution i have so far :
i run my lanuage change macro on the  .sldprt
so  99% of all forgein language becomes english
then i open the .slddrw
and run this macro
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set Part = swApp.ActiveDoc
Set swModel = swApp.ActiveDoc
If swModel Is Nothing Then
        MsgBox " Warning! No active drawing ! Select your drawing and try again"
        Exit Sub
If swModel.GetType <> swDocDRAWING Then
        MsgBox "Warning! No drawing Loaded ! Load / Open an drawing and try again"
        Exit Sub
boolstatus = Part.SetupSheet5("Sheet1", 12, 12, 1, 1, False, "c:\programdata\solidworks\solidworks 2014\lang\english\sheetformat\A3FabricationSheet.slddrt", 0, 0, "Default", True)
MsgBox "Successfully Changed the sheet format ! "
after that i go and clean the drawwing up some more by removing actual text in the drawwing ( in the picture the nite with A-A)
what i like the macro to do is also change the names in the feauture manager
to anything preferebly the normal names
i tried running the macro to change the language
but it only change the first 2
and the macro above here already changes the second on to sheet1
here is another example on the .sldprt
multi language  with a ton of mistakes in it
before
after
can anyone help me a little ? with doing the same thing but then for drawwings
