Dear All,
I have this issue: I have an assembly with a Part inside. Some features are inside the part and some other features are on the assembly. In this particular case I have made a relation between the center of the Hole with the center of the Fillet. One on the Part created inside the Part and one on the Part but created inside the Assembly.
If I update the fillet radius (from 30 to 10 as example) that is inside the part, the position of the hole will be automatically updated. BUT if I do the same on the fillet created inside the assembly (as assembly feature) the hole remains in the old position. Ctrl-Q. Tested.
The only way for me is to OPEN the Part, then Ctrl+Q, then Save the Part and then, the hole in the assembly is in the correct position.
OK. Maybe I forgot something? It seems like a simple thing but I don't know how to solve this.
Solidworks 2017 x64 SP2
Thank you!!!
Gabriele
Hi Gabriele,
I just double checked with 2015 and 2016. In both releases it works as expected. When you modify the fillet, the hole will update after a rebuild. This does not happen in 2017 and I guess it is broken.
Gabriele, you should report this issue to your reseller so that they forward it to our support team and this issue becomes a SPR. There is unfortunately not a lot more what you can do about it.
Kind regards
Frank
SOLIDWORKS Product Definition Team
