Macro doesn't import each file and point
Question asked by Tristan Clark on Mar 19, 2017
Latest reply on Mar 21, 2017 by Ivana Kolin
I have a macro that loops through .sldcrv files with XYZ coordinates in each as a point. For some reason, it'll run through every other file each time it is run. Also, it won't import all the points on the first run. I end up having to run the macro multiple times before all the points are imported. Any ideas? Here is the macro I am using:
Dim swApp As Object
Set Part = swApp.ActiveDoc
swApp.ActiveDoc.ActiveView.FrameState = 1
Dim skPoint As Object
Dim num1 As Integer
Dim nsec As Integer
    nsec = 21
    For num1 = 1 To nsec
    Open "\sec" & num1 & ".sldcrv" For Input As #num1
    Part.SketchManager.Insert3DSketch True
    Do While Not EOF(num1)
    Input #num1, X, Y, Z
    Set skPoint = Part.SketchManager.CreatePoint(X, Y, Z)
    Loop
    Part.InsertCurveFileEnd
    Close #num1
    Next num1
Part.ShowNamedView2 "*Isometric", 7
Part.ViewZoomtofit2
Thanks.
