How do you delete a study in CosmosMotion 2007? I would like
to clear out a study and re-create it. I know the CosmosWorks
allows a study to be deleted, but I cannot find this option in CM
2007.
I called my SW VAR, and we did a web meeting. He could not locate this option either. I noticed if I suppress the parts, and select the CM motion button, it will add duplicate instances of the same parts or sub-assemblies.
Second question: If a study is created without fasteners (shoulder bolts), does 3-D contact need to be manually added to the part linkages?
There are 2 ways in 2007 as I recall:
1. Delete all moving and ground parts on the motion tab (they move back under assembly components). This will clear all entities associated with them so you should be back to square 1.
2. Create a new assembly from the assembly with your model (so it's a sub assembly) and then dissolve the subassembly.
The second technique completely purges all existing motion data so it can be useful.
Cheers,
Ian
