Hello all,
I've been trying to setup a drawing template, and have become stuck. I would like to be able to use revision tables to automatically rev up prints. I've been able to do that with $PRP:"SW-Revision" in a text box. However, my company uses multiple sheets within a drawing file, so each sheet has its own revision level. I see the fact that a custom property is created when I create a revision level on my drawing (it's called Revision-Sheet1, Revision-Sheet2, etc.). I'm also able to create a text box that will link to this property, but if I place it on a template, it will always refer to the same sheet. What I would like is to be able to create a text box that links to Revision-SheetN, where N is the current sheet.
I've tried $PRP:"Revision-Sheet$PRP:"Current Sheet"", but that just gives me a blank.
Anyone had any luck with this or know how to get this to function. Seems simple enough, but I can't get the text box to adjust properly.
TK
You can change your sheet template/format all you want, but the driving information comes from the part or assembly file... You need to add those Revision notes to the part/assembly files and then read them in the drawing.. Do you use Custom Property Tab Builder??
