I have made the core and cavity many times with a single LEGO, but with both the core/cavity can't make because appears the message "cannot knit sheets together mold".
Thank for your attention.
Oscar,.. I don't have 2013 installed.. so, I opened in 2014 and I can get a Tooling Split using your Croquis2 sketch without error.
But... one obvious issue is, your Core/Cavity are not correct, they should be the opposite,.. you can drag/drop each into the other core/cavity folders.
Anyway, maybe someone with 2013 can help respond or see the knit error?
My SW version is 2013
