Log in to create and rate content, and to follow, bookmark, and share content with other members.
A simple extrusion keeps failing. It is on top of a bottle shape which has been twisted with the flex tool. Fails due to 'geometric conditions'. Any help would be awesome! Ive attached the file as well...
Question asked by Ed Hopson on Mar 16, 2017 Latest reply on Mar 16, 2017 by Kevin Pymm
If you untick the "Merge Result" option, your extrude will work & you will get two solid bodies. It won't work as you are trying to do it because your sketch is only in contact with the main body along one edge, causing the dreaded zero thickness geometry.
Edward,
Plane3 does not lay flat on the top surface, so the "merge results" is whats causing the error
Use plane1 instead
