56 Replies Latest reply on Mar 23, 2017 10:36 AM by Tim Webb
    MACRO TO READ TXT FILE
    Korbi Anis
      Hi friends , I need a macro to read the txt file especially line beagan with "Vertex" ! I want to read the coodinates after every "vertex" word. in attachement you will find my TXT.file
        • Re: MACRO TO READ TXT FILE
          Christian Chu
          You can google this
          Here is the one
            Tim Webb
            Korbi,
            If my response provided the solution, I would appreciate you marking my response as the correct response.
            Thanks!
            Tim
              Korbi Anis
              Hi friends , emm Maybe I waant to do some changements on the macro . the coordinates are decalared like String . so I want to read them like double. So I like I saidd before I wanto to read stl file espacially lines began with Vertex (word) and read coordinates rint the right side like Double . can you help me ! thanks
                  Christian Chu
                  use cdbl function which will covert string to double
                      Korbi Anis
                      Dear Christian , I changed the macro using cdbl function but it deas not work too !!
                      Dim strFilename As String: strFilename = "C:\jk.stl"
                      Debug.Print strFilename
                      Dim strTextLine As String
                      Dim iFile As Integer: iFile = FreeFile
                      Open strFilename For Input As #iFile
                      Debug.Print strFilename & " Opened."
                      Do Until EOF(1)
                          Line Input #1, strTextLine
                          Dim TempString As String
                          TempString = UCase(Trim(strTextLine))
                          'Debug.Print "TempString = " & TempString
                          If Left(TempString, 6) = "VERTEX" Then
                              Dim myString As String
                              Dim coordinates As String            ----------------> ( I changed it to "Double")
                              coordinates = Right(TempString, Len(TempString) - Len("vertex"))     ---------> cdbl( coordinates = Right(TempString, Len(TempString) - Len("vertex"))   )
                              Debug.Print "Found vertex with coordinates: " & coordinates
                      Loop
                      Close #iFile
                      MsgBox "Process complete."
                          Christian Chu
                          I don't see any line which you included the cdbl function
                          should be like this
                          dim dCorrd as double
                          dCoord = cdbl(StringofCharacter)
                              Korbi Anis
                              I changed it ! but the same probleme it does not work I think thare are a mistake anywhere
                              Do Until EOF(1)
                                      Dim coordinates As Double
                                      coordinates =  cdbl( Right(TempString, Len(TempString) - Len("vertex"))   )
                              Loop
                              Close #iFile
                                  Christian Chu
                                  Not sure what you mean it didn't work
                                  Please capture the debug.print and post here
                                  Can you break down
                                  dim sTemp as string
                                  sTemp = Right(TempString, Len(TempString) - Len("vertex"))
                                  and dim dTemp as double
                                  dTemp = cdbl (sTemp)
                                        Christian Chu
                                        Put  comment on 2 lines as shown on the image and capture the screen of debug of
                                        debug.print coordinates and post here, please
                                        I suspect, there comma between  the string ???
                                              Korbi Anis
                                              lI did some research on google and I found that CDBL function is used like this CDBL( expression)
                                              so the probleme I think that our expression is a coordinates for example like this  : "8.1012954711914062 -59.383426666259766 39.932231903076172" ....
                                                  Christian Chu
                                                  I got it now, it's space, not comma
                                                  The expression is ok, I just wanted you to break so I can see what it is
                                                  There are spaces between the numbers, you need to break them before you can convert each to double
                                                      Korbi Anis
                                                      I think we have the same idea but how can I delete the space in the expression and after read each nupmber alone like a double ?
                                                          Christian Chu
                                                          Try this to break x, y, and  z corrd - replace sTemp with  your coordinates
                                                          Dim sTemp As String
                                                          Dim strArray() As String
                                                          sTemp = "-12.21548 12.35589 -15.232145"
                                                             strArray = Split(sTemp, " ")
                                                             For i = LBound(strArray) To UBound(strArray)
        Debug.Print Trim(strArray(i))
                                                             Next
                                                          Here is what I got from this code
        Korbi Anis
        now its ok I can read each coordinate separately but when I tried to use CDBL function its does not work
        Korbi Anis
        very strangr !!! for me the macro does not work offff !!
        Do Until EOF(1)
        Dim sTemp As String, stemp2 As String
        Dim dTemp As Double
        stemp2 = Trim(strArray(i))
        dTemp = CDbl(stemp2)
        Next
        Loop
        Close #iFile
        Christian Chu
        Can you comment all the bottom part and show me what's sTemp in the debug.print
        or you can replace sTemp with something like "12.12354 -25.2325488 45.2325888" and run the macro
        Tim Webb
        Hi Korbi,
        I had a few minutes this afternoon to absorb your intent and determine what you needed...then wrote some code.
        You need a "structure" to store the coordinates so I've added one called "PartCoordinates" then Dim'd an array of that structure type to stuff all the coordinates into.
        Here's the complete code. It works well.
        Dim swApp As Object
        Private Type xyzCoordinates
        xcoordinate As Double
        ycoordinate As Double
        zcoordinate As Double
        End Type
        Dim PartCoordinates() As xyzCoordinates
        Dim strFilename As String: strFilename = "<full file path to the STL file>"
        Dim i As Integer
        i = 0
        Do Until EOF(1)
        Dim finalcoords() As String
        coordinates = Trim(Right(TempString, Len(TempString) - Len("vertex")))
        finalcoords = Split(coordinates, " ")
        Debug.Print "finalcoords(0): " & finalcoords(0)
        Debug.Print "finalcoords(1): " & finalcoords(1)
        Debug.Print "finalcoords(2): " & finalcoords(2)
        If i = 0 Then
        ReDim PartCoordinates(0)
        Else
        ReDim Preserve PartCoordinates(UBound(PartCoordinates) + 1)
        PartCoordinates(i).xcoordinate = CDbl(finalcoords(0))
        PartCoordinates(i).ycoordinate = CDbl(finalcoords(1))
        PartCoordinates(i).zcoordinate = CDbl(finalcoords(2))
        i = i + 1
        Loop
        Dim j As Integer
        For j = 0 To UBound(PartCoordinates)
        Debug.Print "x-coordinate: " & CStr(PartCoordinates(j).xcoordinate)
        Debug.Print "y-coordinate: " & CStr(PartCoordinates(j).ycoordinate)
        Debug.Print "z-coordinate: " & CStr(PartCoordinates(j).zcoordinate)
        Next j
        Close #iFile
        I've highlighted the code I added today to get it to work.
        Hope this is the solution to what you need.
        Tim CEPA
        Believe in The Q!
        Korbi Anis
        Hi dear Tim , sorry to be late , Thank you very much forThis code! Unfortunately I tried to run it but it does not work
        Tim Webb
        Ok Korbi
        Please paste ALL your code from this module. I have a feeling you left something out like declaring the PartCoordinates above like this:
        Korbi Anis
        Hi Tim , thanks for your aswer !    This is the code that I used but it does not work yet !
        Dim swApp As Object
        Private Type xyzcoordinates
        End Type
        Dim PartCoordinates() As xyzcoordinates
        Debug.Print strFilename & "Opened."
        Dim i As Integer
        i = 0
        Do Until EOF(1)
        Debug.Print "TempString=" & TempString
        If Left(TempString, 6) = "vertex" Then
        Debug.Print "Found  vertex  with coordinates :" & coordinates
        finalcoords = Split(coordinates, "")
        If i = 0 Then
        Else
        i = i + 1
        Loop
        Dim j As Integer
        Debug.Print "y-coordinate: " & CStr(PartCoordinates(j).xcoordinate)
        Debug.Print "z-coordinate: " & CStr(PartCoordinates(j).xcoordinate)
        Next j
        Close #iFile
        Korbi Anis
        Very strange I tried to evaluate to macto another time and it s the same probleme . I don't understand what's the mistake !
        Tim Webb
        Hi again Korbi!
        It's not very strange and yes it was a mistake you made, you didn't copy and paste the entire code! I ran your code and it doesn't work for me either and I found the error but I'm not going to tell you because I can see you did not copy the entire code block into your program.
        Please, if you are going to ask for assistance, copy and paste the entire code block provided by those who help you because it was a simple troubleshooting error where you left out a space. Do I have your word that you will copy and paste the whole code block?
        Here is the final code I am running which works! I added a little bit more code to tighten up the scan but I'm not going to tell you where it is because I don't want you to just try to copy one or two lines, I want you to copy this ENTIRE code block and REPLACE your ENTIRE code block with this block.
        Dim swApp As Object
        End Type
        Private Const ScanText As String = "VERTEX"
        Dim strFilename As String: strFilename = "C:\Users\tim.webb\OneDrive\Business Development\EPDM add-ins\SW Read STL file coordinates\STL File\jk.stl"
        'Debug.Print strFilename
        Dim i As Integer
        i = 0
        Do Until EOF(1)
        '    Debug.Print "TempString = " & TempString
        If UCase(Left(TempString, 6)) = ScanText Then
        coordinates = Trim(Right(TempString, Len(TempString) - Len(ScanText)))
        '        Debug.Print "Found vertex with coordinates: " & coordinates
        '        Debug.Print "finalcoords(0): " & finalcoords(0)
        '        Debug.Print "finalcoords(1): " & finalcoords(1)
        '        Debug.Print "finalcoords(2): " & finalcoords(2)
        If i = 0 Then
        Else
        i = i + 1
        DoEvents
        Loop
        Dim j As Integer
        DoEvents
        Next j
        Close #iFile
        Tim CEPA
        Believe in The Q!
                                                      Korbi Anis
                                                      If we consider this macro for example , the result is the string in the right side for exemple : [ 0.88582742214202881 -64.497276306152344 39.931648254394531]   ok ? so the goal is to transform this side in Double but the probleme that if we transform it directly l As Double the macro wel read it like a same number not separately number  ( X=0.88582742214202881 , Y=64.497276306152344  , Z=39.931648254394531) . I need your help friends !
                                                      Do Until EOF(1)
                                                              Debug.Print coordinates
                                                      Loop
                                                      Close #iFile
