I'm trying to add ordinate dimensions to my flat patters with a macro. I can not get this macro to work for me? Solidworks 2015
Question asked by Luke Langreck on Mar 16, 2017
Latest reply on Mar 16, 2017 by Luke Langreck
I'm trying to add ordinate dimensions to my flat patters with a macro this is an example from Solidworks.
The two lines I have bold are causing the code keep having a run time error.
Option Explicit
Dim swModelDoc As SldWorks.ModelDoc2
Dim swDrawingDoc As SldWorks.DrawingDoc
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swDisplayDimension As SldWorks.DisplayDimension
Dim status As Boolean
Dim errors As Long
Dim useDoc As Boolean
Dim arrowSize As Double
    Set swModelDoc = swApp.ActiveDoc
    Set swDrawingDoc = swModelDoc
    Set swModelDocExt = swModelDoc.Extension
    status = swDrawingDoc.ActivateView("Drawing View1")
    'Create ordinate dimension
    status = swModelDocExt.SelectByID2("", "VERTEX", 8.76609155372049E-02, 0.255953076919585, -499.97349537912, False, 0, Nothing, 0)
    status = swModelDocExt.SelectByID2("", "VERTEX", 9.54286078448972E-02, 0.256322967029476, -499.97349537912, True, 0, Nothing, 0)
    errors = swModelDocExt.AddOrdinateDimension(swAddOrdinateDims_e.swHorizontalOrdinate, 0.094688827625117, 0.272968021978022, 0)
    'Add an ordinate dimension
    swModelDoc.ClearSelection2 True
    status = swModelDocExt.SelectByID2("", "VERTEX", 0.101346849603139, 0.257062747249256, -499.97349537912, False, 0, Nothing, 0)
    swModelDoc.SetPickMode
    'Change the diameter of the circle of the base ordinate dimension
    status = swModelDocExt.SelectByID2("D1@Sketch3@2012-sm.SLDDRW", "DIMENSION", 8.78551078448972E-02, 0.275113384615385, 0, False, 0, Nothing, 0)
    Set swSelMgr = swModelDoc.SelectionManager
    Set swDisplayDimension = swSelMgr.GetSelectedObject6(1, -1)
    swDisplayDimension.SetOrdinateDimensionArrowSize False, 0.00288
    swDisplayDimension.GetOrdinateDimensionArrowSize useDoc, arrowSize
    Debug.Print "Base ordinate dimension diameter of circle for arrow: " & arrowSize * 1000 & "mm"
