Ok reading though some other posts. some work some don't.but
from the help system:
- If the option Show sheet format dialog when adding new sheet from Options
, Drawings is not selected, and the Drawing Sheets document property is not set, a new sheet is added using the format of the existing sheet.
have my system set this way. if I add a second sheet to the drawing file all I get is a blank standard sheet. not the "a new sheet is added using the format of the existing sheet."
if I copy/paste the first sheet it all 'works' other that having to delete the views already on the sheet. .
is there some trick I'm missing? likely....
first time I've had a use for the multi sheet built in to SW..
thanks
jb..
There are two possibilities that I can think of:
1) The current sheet format has been changed or moved and can't be located.
2) This option isn't selected in the sheet Properties:
