A little background…
I am working at home with a company that is another city (3.5hrs away). I am logging into their system and accessing their vault. I had installed 2013 (cause the company was running it) and had to uninstall a windows update from 2015, that was causing the addin not to show up in 2013. After the company moved to 2017 last week, I uninstalled 2013 and started using 2017 which I had already installed months prior. So, yesterday I updated the system with all current window updates and the addin is not showing up. I was debating on re-installing SW late last night, but didn’t want to delete any pdm settings already set up from the company.
Any help would be appreciated. Thanks in advance.
Regards & God Bless America
Dean Williamson
Owner/Veteran
Williamson 3D Drafting & Design, LLC
contact@williamsons3ddrafting.com
3008 Chestnut Street
Cuba, Mo 65453
C:573-690-9527
Hi Dean,
You won't need to reinstall SOLIDWORKS, just modify the SOLIDWORKS PDM program in the Windows Control Panel. During setup see p.92 of the 2017 PDM installation guide. This will show you how to activate the SOLIDWORKS PDM add-in. The part you will need to make sure to follow is the section below called "Select Add-ins".
