Hi everybody,
I've just started to use solidworks electrical for a new client that requires wire harness installation design. I have quite a bit experience using CATIA V5 electrical, but SolidWorks electrical is new to me. My issue is that I can't enable most of the wire routing tools ( route harness, route wires, segregation, set origin/destination for cables), the only tool that I can use is 'create routing path'. Based on my client IT support, I'm supposed to be able to use the solidworks electrical license in its entirety, so license access I don't think is the problem. Any thoughts?
Thanks for your support!
Hey Jose,
Do you have routing available in your Add-Ins (Tools -> Add-Ins) and is it enabled? What do you see when you click on Help -> My Products?
Thanks!
