OK so, below you will find my current macro, works nearly flawlessly. alas it is so inefficient it hurts... (as you can see if you watch the debug window).
What it does is it gets all components and configurations of said components in an assembly. It then iterates through them using a duplicate iteration to count the quantities of each configuration of each component. Using this method it overwrites the "MfgQty" custom property again and again every time it encounters a part. Though it still gives the correct result, this is horribly inefficient.
Dim swCmp As SldWorks.Component2
Dim tCmp As SldWorks.Component2
Dim CmpDoc As ModelDoc2
Dim i As Integer
Dim j As Integer
Dim Cfg As String
Dim vCmps As Variant
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Dim nstart As Long
Dim nStatus As Long
Dim config As SldWorks.Configuration
Dim lRetVal As Variant
Dim ValOut As String
Dim ResolvedValOut As String
Dim wasResolved As Boolean
Dim cCnt As Integer
Set swModel = swApp.ActiveDoc
Set swAssy = swModel
' start timer
nstart = Timer
' load all components into array
vCmps = swAssy.GetComponents(False)
' resolve all lightweight components
nStatus = swAssy.ResolveAllLightWeightComponents(False)
'remove duplicates from array
' iterate though array
For i = 0 To UBound(vCmps)
Set swCmp = vCmps(i)
If (swCmp.GetSuppression = 3) Or (swCmp.GetSuppression = 2) Then
cCnt = 0
Set CmpDoc = swCmp.GetModelDoc
Cfg = swCmp.ReferencedConfiguration
' for each component in new array of matching configuration, count instances in original array
For j = 0 To UBound(vCmps)
Set tCmp = vCmps(j)
If tCmp.GetSuppression <> 0 Then
If tCmp.GetModelDoc2 Is CmpDoc Then
If tCmp.ReferencedConfiguration = Cfg Then
cCnt = cCnt + 1
Next j
Debug.Print swCmp.Name, swCmp.ReferencedConfiguration, cCnt
' set "MfgQty" custom property to computed value
Set swCustPropMgr = CmpDoc.Extension.CustomPropertyManager(swCmp.ReferencedConfiguration)
lRetVal = swCustPropMgr.Delete2("MfgQty")
lRetVal = swCustPropMgr.Add3("MfgQty", 30, "999", 0)
lRetVal = swCustPropMgr.Get5("MfgQty", False, ValOut, ResolvedValOut, False)
lRetVal = swCustPropMgr.Set2("MfgQty", cCnt)
Next i
' show elapsed time
Debug.Print "Time = " & Timer - nstart & " seconds"
What I would like to do is reduce this. I would like to initially build an array of unique components/configurations, then using that array iterate through it using the base array to do the count. this would benefit me at least 2 fold, 1) MUCH more efficient not duplicating counts and 2) it would allow me to add print and dxf commands in (print to .PDF drawings of all parts, and export .DXF drawings of parts that contain a custom property called "ItemCat" with the value of "Laser-Pur" and/or "Router-Pur"), and only have each unique part print out once rather that 24 times for a part that has 24 instances. Below is a sample code of what i think would work... i am just having issues connecting the two.
Sub Test()
Dim aReturn As Variant
Dim aArray As Variant
Dim swCmp As Variant
' build array
aArray = Array("red", "blue", "green", "blue", "blue", "green", "red", "red", "yellow", "red", "green", "blue")
aReturn = ArrayUnique(aArray)
For i = 0 To UBound(aReturn)
Debug.Print aReturn(i)
Next i
Function ArrayUnique(ByVal aArrayIn As Variant) As Variant
'remove duplicated values from a single dimension array
Dim aArrayOut() As Variant
Dim bFlag As Boolean
Dim vIn As Variant
Dim vOut As Variant
Dim i%, j%, k%
ReDim aArrayOut(LBound(aArrayIn) To UBound(aArrayIn))
i = LBound(aArrayIn)
j = i
For Each vIn In aArrayIn
For k = j To i - 1
If vIn = aArrayOut(k) Then bFlag = True: Exit For
Next
If Not bFlag Then aArrayOut(i) = vIn: i = i + 1
bFlag = False
Next
If i <> UBound(aArrayIn) Then ReDim Preserve aArrayOut(LBound(aArrayIn) To i - 1)
ArrayUnique = aArrayOut
End Function
the first code has fairly well broken out steps, and works as is to add a custom property called "MfgQty" to each file with the assembly count of said part. Works with multiple configurations of the same part and will add the property to each configuration correctly.
Any help on generating this Array so i can progress this code further would be helpful. as you can see the " 'remove duplicates from array" section is empty
