This happens on everything I animate in Visualize. Am I doing something wrong? Whenever I duplicate a keyframe and move it over to the right it changes all the settings around. I need parts to remain stationary for a selected time then start moving again later in the timeline. Right now when I duplicate a camera keyframe or part keyframe it always adds a strange wiggle or bounce effect. I have tried duplicating keyframes and also scrubbing to the right time then hit the shit+ctrl+K to add a keyframe, but it still adds the bounce/shift effect.
Also something else I discovered, if you have multiple layers in the timeline and select two or more keyframes to drag to a different location they get out of sync. All the keyframes will stagger slightly with the one I am holding leading the pack. I can include a screenshot if needed.
Lastly if a keyframe is selected and you hit the delete button, it deletes the entire timeline and part. Can this be changed?
Hi Chris, you can edit keyframes.Right click on a keyframe, choose edit.In the Keyframe-Transition Panel select hold instead smooth.
This will freeze the the part/camera until the next keyframe.
