I have been trying to find a way to make my route sketch dimensions and drawing dimensions in inches but then have the length of pipes in feet in the BOM. I was hoping to have this length appear in the quantity column of the BOM. Does anyone have suggestions on how to do this? I have played around with changing the document units in the for the pipe files themselves, the units for the pipe assembly, and the units for the parent assembly that route is in but am still having issues. It seems the only way I am able to get the units to display as feet on a drawing is to set the drawing units to feet, but that also causes all of my dimensions to display as feet.
Set the document units to Feet, so that BOM units are correct. And then select all dimensions and manually (from other tab) set their units to Inches.
