26 Replies Latest reply on May 3, 2017 3:57 PM by Corry Schneider
    Linking custom property to drawing view name
    Corry Schneider
      I have a weldment drawing with the assembly in its finished state.
      3 "default" configuration views on page 1, top, front, and right.
      Page 2, BOM with "weldment" configuration in iso view, balloon and weldment callouts galore.
      Page 3+, all the steel parts in their finished states.
      Problem: how do I rename all these views with the correct description from the custom property in the correct configuration of the assembly/part, followed by the view orientation? The goal is to reduce errors by reusing existing data and hyperlinks in the PDF which will take you directly to the desired view.
      Is a macro the best way to do this? If yes, does one already exist, if not, can someone please help me make one?
      Thanks in advance,
        • Re: Linking custom property to drawing view name
          Jim Steinmeyer
          Corry,
          From the way your question is worded I am assuming that you have custom properties created for names of the appropriate views. If not we will have to go a little deeper.
          If you do the first thing you need to do is either double click on the existing view description or create a note if one does not exist. Then with the note active look at the circled icons in the following screen shot. The left icon will insert a hyperlink and the right one will link to custom properties in the model or drawing.
          Now you can select to use properties from either the current document (drawing) or the model. You can select the current view or a different component. and then you can select the desired property. This includes different configurations. Hopefully this will help with your challenges.
              Corry Schneider
              True, but I was hoping all I would have to do is click a macro and this task would be accomplished for all 60+ views in the document. As it is I am spending half an hour just renaming the views.
                  Matt Peneguy
                  Corry,
                  I had a macro I kludged together to get a custom property into an annotation a few years ago.  I modified it to overwrite whatever the text selected and set it to the configuration name.  It may help you:
                      Dim swApp                       As SldWorks.SldWorks
                      Dim swModel                     As SldWorks.ModelDoc2
                      Dim swSelMgr                    As SldWorks.SelectionMgr
                      Dim swAnnObj                    As Object
                      Dim swAnn                       As SldWorks.Annotation
                      Dim swoNote                     As Note
                      Dim swTextFormat                As SldWorks.TextFormat
                      Dim i                           As Long
                      Dim bRet                        As Boolean
                      Dim j                           As Integer
                      Set swModel = swApp.ActiveDoc
                  For j = 1 To swSelMgr.GetSelectedObjectCount2(-1)
                      If swSelMgr.GetSelectedObjectType3(j, -1) = swSelNOTES Then
                          Set swAnnObj = swSelMgr.GetSelectedObject5(j)
                          Set swAnn = swAnnObj.GetAnnotation: Debug.Assert Not Nothing Is swAnn
                          ' Get text format information
                          Debug.Print "File = " & swModel.GetPathName
                          Debug.Print "  " & swAnn.GetName & " <" & swAnn.GetType & ">"
                          For i = 0 To swAnn.GetTextFormatCount - 1
                              Set swTextFormat = swAnn.GetTextFormat(i)
                              ' Change text to be 10mm high, bold, italic, and Comic Sans MS font face
                              'swTextFormat.CharHeight = 0.01
                              ' -------CHANGE POINTS TO 24 FOR TITLES
                              swTextFormat.CharHeightInPts = 24
                              swTextFormat.Bold = True
                              swTextFormat.TypeFaceName = "SWRomnd"
                              bRet = swAnn.SetTextFormat(i, False, swTextFormat): Debug.Assert bRet
                          Next
                          If swAnn.GetType = swAnnotationType_e.swNote Then
                                      Dim swNote As SldWorks.Note
                                      Set swNote = swAnn.GetSpecificAnnotation
                                      Dim myval As Boolean
                                      myval = swNote.SetText("$PRPVIEW:""SW-Configuration Name(Configuration Name)""")
                          Set swoNote = swAnn.GetSpecificAnnotation
                          If swoNote.IsBomBalloon() Then
                              swNote.SetBalloon swBalloonStyle_e.swBS_None, swBalloonFit_e.swBF_3Chars
                              swAnn.SetLeader3 swLeaderStyle_e.swNO_LEADER, swLeaderSide_e.swLS_SMART, False, False, False, False
                  Next j
                Corry Schneider
                To start, I wrote this code:
                Dim swView As SldWorks.View
                Set swDraw = swApp.ActiveDoc
                Set swView = swDraw.GetCurrentSheet.GetViews()(0)
                swView.SetName2 ("$PRPVIEW:""SW-Configuration Name(Configuration Name)""")
                So yeah, the feature tree shows what I want, the view note says what I want, but the content should say, 42" DIA.
                Am I missing a line to activate the call?
                  Corry Schneider
                  Do we have any updates? I have been working on another project, but I would still like to automate the naming of the views in drawings.
