Is there a way to lock the units of the measure tool? For example, I set them to dual (inches/mm) and as I work, they change to mm/mm. It may be when I insert a metric part into my assembly.
I would like the units to always be dual and always be a certain decimal place.
Hi Gary,
Do you use a defined template when creating a new assembly?
For an immediate fix, go to Tools>Options
Select the document tab, then select Units, then select Inches/MM as you require.
Dave
