How do I change the pivot center of a group? I want the pivot center to be at the base of the group, not the exact center. Is there a way to hold alt and shift and drag the transform box to relocate the pivot center? Or some other similar combination of buttons?
Hi Chris,
You can snap to the beginning, middle and ends of a part/group/model's overall bounding box. First enable the 'Pivot' tool from the Main Toolbar:
The click on any of the axis arrows in the Pivot widget and hold down CTRL. This will show matching axis color small sphere to the points where you can snap the pivot:
Currently, you cannot select a specific point on the geometry to snap the pivot, only these predefined beginning, middle, and end points of the overall bounding box.
