I have been using Import STEP File Example (C#) as a template for importing step files into solidworks. The issue I am having is I get prompted for what template to use so I'm trying to figure out how to programatically tell the computer to use a certain template for assemblies and a certain one for parts. I do have my System Options set to Prompt user to select document template and I cannot change the System options to Always use these default document templates. I could programatically change it then change it back but i would rather not.
In short the user will select a list of step files they want converted and select weather they want to Save then as Default or Part documents and walk away with the program converts the files.
Check if you can use this Import 3d tool from #TASK
