This part is inserted and mated plane to plane. Then, plane to axis and plane to axis. This part is NOT fully defined. I should still be able to rotate it about the axis by picking to more planes and entering the angle. SW tells me this would over define the part. I have done this before (pre-v2016) and it has worked fine.
What's the problem?
Could you upload the part you need this part to mate too?
