Adding PDM access/functions to a simple macro (VBA)
Question asked by Cad Admin on Mar 3, 2017
Latest reply on Mar 3, 2017 by Jason Kerns
I have a (few) simple macros i use that has code to update a models custom properties from a drawing. Currently It does everything silently, without opening the file.  Current code works fine.  Now i have a PDM system that requires the file to be checked out to change the model.
I have (2) options:
First option: Is there a way to add "silently" checkout so the properties can be updated. (don't really care about checking it back in)
or
Second option: find out if the part model associated with the drawing "is" checked out, and if i can then prompt to do so
Option Explicit
    Dim swApp                       As SldWorks.SldWorks
    Dim swModel                     As SldWorks.ModelDoc2
    Dim swDraw                      As SldWorks.DrawingDoc
    Dim swView                      As SldWorks.View
    Dim swCustProp               As CustomPropertyManager
    Set swDraw = swApp.ActiveDoc
    Set swView = swDraw.GetFirstView
    Set swView = swView.GetNextView
    Set swModel = swView.ReferencedDocument
    Set swCustProp = swModel.Extension.CustomPropertyManager("")
    swCustProp.Set "Description", "Test"
