I downloaded a Solidworks model of the space shuttle, but I need to remove the engines so the back surface is flat. When I try to delete the entries and fill in the groove, I am then unable to mirror the parts, and it tells me the sketch is under-defined.
Here is the download link GrabCAD - CAD library
I would like the remove the engines, and fully attach the rudder to the surface. I was able to connect it but it still said undefined.
Please help! Thanks
hei'ya Michelle,
if you use the rollback bar to examine
the building of the features-
i.e. rollback to the beginning of the
features you wish to edit/remove
and then rebuild to a stable edited
version of the model you want
that's about it - hope this helps
have a good'n kelef
