Bernie Daraz
Using Center Rectangle Sketch for Hole Wizard Pattern
Discussion created by Bernie Daraz on Mar 3, 2017
Latest reply on May 24, 2018 by Rebecca Bennett
I have read more than a few comments on using the Center Rectangle for Hole Wizard patterns and how the Center is automatically populated with a Hole Wizard hole. I believe it was @Glenn Schroeder that suggested it in a separate sketch which works. May I suggest that you use a regular rectangle with a singular construction line constrained to the midpoints of the lines and also constrained to the desired origin.
